Alan,
Thanks for the reply.
Never had to bleed my brakes, so no brake bleed kit alas.
I was planning to do it 2 man style
(well me and the g/f!) so no non return valve required, just a strong pumping leg and much patience
(I Gather)
off to homebase on the way home for some tiny tubing!
Anything else I need to consider? I know I have to:
1) Check I can open bleed nipple before I do anything towards changing the master cylinder.
2) Pump Pedal few times
3) Crack bleed nipple until pressure relieved
4) Dont let pedal up until nipple closed again
5) rinse and repeat until g/f has leg like popeye
I will post some pics once I'm allowed and generally introduce myself more when I'm not running the gauntlet of the IT bods
![Smile :)](./images/smilies/icon_smile.gif)
