What's the best/biggest battery...?
shabz
Post by shabz »
What's the best and most reasonably priced battery you can fit in a mk2 rev3 mr2 turbo?
I'm gunna be installing an amp/components/sub setup at some point soon so it will need to have enough juice for that (nothing crazy- probs around 300wrms in total)
cvega666
Re: What's the best/biggest battery...?
Post by cvega666 »
optima batteries were the batteries of choice for big audio installs... (well last time i did anything with car audio, anyway)
http://www.optima-batterien.eu/optima-a ... nment.html
shabz
Post by shabz »
which model/size optima will fit?
i think the standard battery is a 005L 60Ah...can you fit a bigger one than that?
cvega666
Post by cvega666 »
i dont have a ruler handy but someone surely can sort you out with dimensions of the battery box...
toxo
Post by toxo »
You don't want to fit a (much) bigger battery for that stuff as you'll just overload your alternator trying to charge it, unless you intend on running your ICE with the engine switched off? In which case a split charging relay and a separate leisure battery would be the way to go (not a car battery).
shabz
Post by shabz »
based on everyone's suggestions i think a stock battery will do the trick
any recommendations on which brand/where to buy?
Harold
Post by Harold »
shabz wrote:based on everyone's suggestions i think a stock battery will do the trick
If you have access to a halfords trade card then just get one from there, you get big discounts on batteries. Bought a halfords brand one the other week that should have been £84 and the discounted price was £52.
madbasshunter
Post by madbasshunter »
I would recommend the optima yellow top which is what I have in mine and The Big 3 which is putting bigger cable (0gauge preferably) from the alternator to the battery (leaving the original wiring as well) from the engine to earth and from the battery to the body.
TbarSAN
Post by TbarSAN »
I bought one from performancebatteries.co.uk last year :thumleft:
£55 and (really,if you order early...)next day delivery :shock:
Say your friend gave you a 5% discount card as well :wink:
I missed the turbo boost but don't miss the 2 at all...
paul port
Post by paul port »
Get the car battery from a Toyota Dealer.
Better price and Warranty than Halfords etc, and you know it will fit!
ryan
Post by ryan »
Varta are top quality batteries that are fitted to many new high end cars. They have a 3 yr warranty but they really are good batteries
cosmos
Battery
Post by cosmos »
Halfords Bosche Silver 005 calcium technology discount card £110 to £85ish HCBOO5??? Good lifting handle!!!
Olly.Dent
Post by Olly.Dent »
Optima mate, I got this one..................
http://www.fourleafbatteries.co.uk/opti ... 727abcb0f7
