Power Fc with datalogit, JE pistons,HKS 264 exhaust and 272 inlet cams that I degreed to 103 and 110 deg, I expected the idle to be a bit rough but this is so lumpy and rich.
I also have an ATS uprated fpv which was ok on my 540 injectors.
It starts up fine and blips up ok
Sard injectors
800 set to 67.5
% and 0.56ms but cannot get it to idle and its running pig rich.
Altering the fuel injector settings makes no difference even if I set them to 60% Did a sensor check all looked good apart from wideband o2 so have disabled it via datalogit but its still rich.
I checked all the vacuum pipes and all looks well cannot see anything obvious
Any
ideas guys as I want to book a mapping session but I don want to wash down the bores
