I'm getting a whine from the rear drivers side of my engine, which I think is alternator related.
The whine is noticeable when idling and changes pitch when the revs are increased.
I know its not much to go on, but does this sound like its the alternator or the belt?
If its the alternator, is it best to replace it or can you change the brushes? Do I even need to change it if it is still charging the battery?
How would I know if its the oval plug or not as well?
Should have said at the start its on a Rev 3 Tubby.
Any help/advice gratefully received.
Andy
