i really dont like the stuck on look, or piller mounted gauges, so i had an idea to mount some 52mm dials in the centre console, they wont quite fit in a single din sized area i dont think (but if anyone has got some then post up a pic). again they wont fit correctly where the vents are, so i plan to chop the plastic bar below the vents/above the double din slot and refix it in the middle of the double din. so id have a single din stereo then the bar then a bigger area to fit the gauges, the new rail can be fibreglassed into place and then have a piece of ali plate fixed into place where the gauges will be mounted. then paint it all as nice subtle colour
i think i can easily get 4 gauges in there, i have a fuel pressure one, i need a wideband afr (for the supercharger), maybe an oil temp and 1 other.
anyone done something similar to keep mounting gauges looking as subtle as poss without dash top pods or the a pillar ones
mounting gauges in the centre console
Re: mounting gauges in the centre console
i had 5 gauges mounted in the centre console still have the console and gauges spare i put carbon fiber into the console then fitted the gauges into that
was that in place of a stereo?
this is what ive just done, i could i think squeeze 5 in there but 3 with better spacing would look miles better
cut out the centre bar for the vents and the one below it
refix the long bar to make a single din space
and before proper fixing make sure the stereo is fine
52mm, single din, no alterations to the radio din section
saw those but i dont like the way they only 'just fit' if you know what i mean
I've not got any pics of mine fitted, but I've got a triple gauge single din adapter. The gauges don't look like they'll overhang the adapter plate, but like I say, I haven't fitted it yet. I'm also planning a couple of trick bits - one I think I stole from here - chargecooler coolant temp snesor (with a twist), which I'm going to mount in the other DIN slot.
Then I'm planning something even better for the heaters/stereo sloution, but it'll probably never happen.
Will be watching how yours turns out though - could be good.
I need to locate 2 60mm gauges, and pillar pods aren't an option.
January 2014
May 2015
Still in the garage...
..the only thing I can promise for sure is slow progress.
May 2015
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.
the only doenside with mine is ill lose the centre vents - no big deal though
Couldn't you fabricate some narrower vents (if losing the vents is of any issue)?
January 2014
May 2015
May 2015
I think the clock is a bit of a waste of premium space too. Don't know many stereos that don't tell you the time....
January 2014
May 2015
May 2015
possibly, making a slot for narrow vents is not problem as i have other stereo surrounds i could use the rail from but its the vents themselves
You could use some vents from a Mazda - iirc, they are round, and might look nice against a few round gauges....
January 2014
May 2015
May 2015
maybe - but hey who needs centre vents they're so last year
Off topic a bit, but do you have any engine hangers off a rev 3 (NA or turbo) from the cambelt end?
January 2014
May 2015
May 2015
Not engine mounts though....
January 2014
May 2015
May 2015
for the back box, or the middle section that goes on the subframe
Neither
It's the bit that bolts into the head by the exhaust manifold. Part 12283 in the bottom left of this picture:
http://www.ayrpark.plus.com/epc/toyota/ ... _1993.html
They look the same on rev 2 & 3, but the two holes at the top are slightly further apart on one of them.
January 2014
May 2015
May 2015
ive just taken a rev4 na engine out and about to take a rev3 na engine out so yeah ill have one
Would you be able to get one to me by Friday do you think? I need to fit my clutch & gearbox, so need to get the engine off the stand.
January 2014
May 2015
May 2015
yes mate no worries, pm me your address and a really good price
(sorry i misread the first post about this as being exhaust hangers )
PM'd - sorry for junking up the thread....
January 2014
May 2015
May 2015
