Hi Guys
.Looked on Ayrpark to see if I could identify the parts I may need for my '93 Rev2 UK GS-FE N/A. It seems Toyota have now stopped them displaying drawings and Part numbers, so couldn't get any help there.
Is there someone on here who would be kind enough to help?
Need to obtain the Toyota numbers for parts from the exhaust gasket and manifold right the way through to the rear silencer box and tailpipes, including cat, all gaskets and crush rings if appropriate.
Info would be most helpful.
Cheers.
[Mk2] [NA] Rev2 exhaust system details
- IMOC Committee
Re: [Mk2] [NA] Rev2 exhaust system details
Definitely an FE?
Exhaust manifold gasket is 17173-74040
Exhaust manifold is an odd one, I can't select it on my EPC PNC is 17141 but that doesn't make a complete part number.
Exhaust manifold studs are 6 x 90116-10063
Exhaust manifold nuts are 6 x 90179-10088
Manifold to frontpipe gaskets are 2 x 90917-06061
Nuts that attach manifold to frontpipe are 3 x 90179-10070
Studs that attach manifold to frontpipe are 3 x 90116-10058
Frontpipe itself is 17410-7A070
Gasket from frontpipe to CAT is 90917-06043
Bolts that bolt frontpipe to CAT are 2 x 90105-10023
CAT is 18450-16380
Gasket that attaches CAT to silencer is 90917-06054
Bolts that bolt CAT to silencer are 2 x 90105-10023
Silencer is 17430-74830. This is the same part as the 3SGE silencer.
Don't tell me, you want to know all the part numbers for the heatshields and exhaust mounts too?
CAT is 18450-16380
Hi Toxo.
D'oooooh !
Many thanks for your response but it's a GS-GE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Oh dear, so sorry. If you still have any patience left...............?
Cheers.
D'oooooh !
Cheers.
think you mean 3S-GE mate
MR22 wrote:Hi Guys
Cheers.
Any good ?
