My mk 2 Rev 4 has recently become very
'skitty' at the rear, and I can't quite figure out why.
I'm not talking about on the limit handling issues, i'm talking about normal road use, examples being:
Whenever a rear wheel goes over a drain cover, even in a straight line, and even with hardly any throttle applied, say at 30 mph, the back end will kick notably sideways
(this even happens in the dry, but it obviously more pronounced in the wet)
On smoothish tarmac, in a straight line with moderate throttle applied, the car can not find traction and the back end will kick from side to side, as if the car is pulling itself from side to side and the diff cant find traction.
I have also had some seriously slow and unprovoked oversteer when exiting round abouts.
Any ideas what is going on? The rear tyres
(toyo proxes T1R) are past their best, but still have 3mm left all over, tyre wear totally even etc.
It's as though the handling has changed almost overnight.
I'm thinking I might take a trip to Pro Tyre at the weekend and get the alignment checked, and then perhaps a new set of boots? For info, Im running supra 16s on the car
(215/45/16 front, 245/45/16 rear), and up until recently the car has handled sweet as a nut.
Any advice would be appreciated
