I have just purchased a fantastic rev2 turbo with the following but have a couple of questions please?
The spec is as follows
Forged CP Pistons
Eagle
Clevite 77 Tri-metal Bearings
Cometic Head Gasket
GT3071r Ball Bearing Turbo
GM Knock Sensor
Wolfkatz Fuel Rail
Sard 800cc injectors
Tial 38mm Wastegate
Walbro 255l/h
ST205 ChargeCooler and Pump
HUGE K&N Air Filter
Blitz Dump Valve
ARP Head Bolts
Helix Single Plate Clutch
Fidanza Flywheel
Sard Fuel Pressure Regulator
Rogue Engine Bay Fans
Blueflame Twin Exit exhaust
HKS Valve Springs
HKS Cam Gears
HKS Timing Belt
264 Exhaust and Intake
Link G3 ECU
Re-conditioned Rev 3 Gearbox.
INTERIOR
180mph Speedo
Omori Boost Gauge 45mm in-dash
HKS Turbo Timer
Electronic Boost Controller greedy pro spec II.
My question is I believe the car is mapped at 1.8 bar can I use the boost controller to set the low setting to 1.1 bar and the high setting at 1.5 bar or would I need to get the ecu remapped to run lower boost?
Also looking at the spec of the engine what kind of boost is safe to run?
I am also looking to get a couple of gauges in he car, after market boost gauge already fitted, but am also thinking oil temp/pressure gauge would you recommend any others?
Thanks in advance
Dom
![Laughing :lol:](./images/smilies/icon_lol.gif)
