It's all about the difference in stiffness between the front and rear.
Stiffer at the front
= understeer, stiffer at the rear
= oversteer
(and yes that is a massive generalisation).
The general consensus of opinion seems to be maximum stiffness at the rear, and the middle setting at the front, I did have both mine set to medium, but soon stiffened up the rear after a few laps, which made cornering far more rewarding, encouraging balancing the turn with throttle input.
.lots of fun.
In the wet it's worth backing the stiffness off a bit, making the handling more neutral, reducing the car's attempts to spin out.
