Have searched but can't seem to find how to change the from headlight bulbs...can anyone tell me a simple way to do it? I presume it's straight forward or is there anything special that I need to take in to account?
Thanks.
P.S. Any good 'how many guitarists does it take to change a light bulb' are welcome!
Help, how to change a light bulb?
Re: Help, how to change a light bulb?
Amazingggg!!! Thanksss!!!
Just make sure you dont do what I did once and `test` the bulb once fitted, before you put the screws back in... Then forget the screws werent back in yet and turn the lights fully off... Dropping the headlight into the body of the car.. lol...
Little bit more detail here and a few tips too
http://www.imoc.co.uk/forums/viewtopic. ... light=bulb
You need a screw driver and masking tape for that action. And make sure that you had a best switching into the changing. Try to remove it carefully and make some point that can fall inside the light bulb.
