Hi All,
I've just taken off the driver's side wing
& door on my MK1A to sort some rust at the bottom of the A-pillar.
Delighted to see that the outer skin was rotten but after grinding off the rusty bits, the inner skin is rock solid.
Just looking at the sunroof drain tube, where does it exit or where is it meant to exit.
I can see it in the pillar but no sign of it coming out.
Does it drain into the sill?.
Also have a good bit of play on the top door hinge but the bottom one is perfect.
This set me wondering if the top
& bottom hinges are the same.
Just thinking about this at work this morning so haven't had time to look.
I have a few spare doors so if I had a good bottom hinge on one of those, I could swap it over.
Anyone know if they are the same.
Tim
