hi guys
quick question - I'm sure all NA owners know this high pitched whining sound that usually comes from the mr2 engine - what is that ? alternator or oil/water pump ?
exactly this sound - high pitched whistle : http://www.youtube.com/watch?v=QA0DBtx34jc
I'm a bit concerned as my car this evening didnt make that sound for a sec, then after a loud screech from a belt it started whining again.
Just wondering what's on the way out
cheers
J
the characteristic "whining" sound... alternator ?
Re: the characteristic "whining" sound... alternator ?
just been looking over some photos of the 3sge and if i understand it correctly i could tighten up the alternator belt myself quite easily.. just asking this before Luke is going to kill me for showing up at his garage 3rd saturday in a row
how much tension should there be in the alt belt ? I can easily press it down with my finger.
weird, my NA has never, ever made that sound! ??????? what is it?
Slarty wrote:
it's just that we subscrible to the theory of hitting it harder until it works. Or something falls off, in which case you've hit it too hard.
dont know! i thought it was the alt, but not sure now, it seems to be coming more from the top of the engine ? ... hopefully someone will know.
i had a similar sound from a vectra once when a cambelt idler was sticky. perhaps its cambelt related?
EDIT: also had similar sound from our old car when i changed the alt belt and it was too tight, just remembered
hmm.... i dont know. I just took it for a spin and it seems ok. but in the morning struggles for a bit, the whining sound is gone, something (belt) screeches loudly and then something (lol, alternator?) starts, the whining sound is back. I'd think the belt is slipping and alternator has some trouble starting to move, but not sure. I'll start it tomorrow morning while looking over the engine bay, perhaps that will give me a clue... the alt belt seems a bit loose if anything, I can easily press it with one finger.
mine make this noise as well! I thought it was the alternator also, however one of my belts has started screeching now (and the noise stops) then its back when the screeching stops
damn you cold wet weather!
blacker than the blackest black, TIMES INFINITY!
hmm.. seems weird to me as I had both the cambelt and alternator belt done too... but it did indeed started happening on one of the colder days.
I have this sound on my Rev1 N/A.
Only picked it up today. Few mates who are on here think its the alternator belt being a bit tight.
Will try and have a look over it this week.
cool, let us know what you find.
My belt is pretty loose, if not too loose. I dont know how tight should it be and how to measure it without any tools. I've browsed thru some forums and apparently it should be so you can twist it with your fingers only about 1/4 of a turn. Mine is a bit floppier than that..
Image it's an idler pulley, mine makes the same noise with an induction kit on it.
could be. On a cold morning I can clearly hear that it has problems moving; for a couple seconds engine is really struggling, but frees up with a screech quite quick. Hopefully not terminal yet, I really wanna stay out of the garage till new years
Reechard wrote:I have this sound on my Rev1 N/A.
Lol rich was just about to link this to your thread on www.built4track.co.uk
Too late Ad, I am already sneaking about on here lol.
Does yours seem to only do it in certain gears or in all gears cvega?
Nope. Starts the moment i start the car, doesnt matter if in gear or not.
Hmmm mine only seems to do it some of the time and mainly in 1st, 2nd and 3rd.
I'll have a look at it on Friday probably, half day at work
does do it in idle, aswell ? in higher gears maybe unaudible?
Hadnt noticed it in idle, not in higher gears that I have noticed.
Turned everything off for a good listen while driving it home.
hmm... mine is always there, just like in the movie I linked.
heres a (rubbish phone) video of mine making that nose
http://s810.photobucket.com/albums/zz28 ... 010001.mp4
It seems to rise with revs, stop at a certain point, then come back again at lower revs (or when i put the fogs on!!)
