Reluctantly up for sale as i am now working over 100 miles from home So I need some thing cheaper to run and something I can get a suitcase in easily.
Right the car is Modified as follows
Apexi AVCR set at 1.1 bar
HKS air intake
XS power type intercooler
Toyo sports downpipe ( cat available if required )
Powerflow exhaust
Hks lowered springs on black Bilstiens
Enkei RP01 wheels 9x17 with 255/40/17 and 8x17 with 215/40/17 tyres.
Turbo was removed overhauled with new seals and bearings 6 months ago.
Recaro seats
The car is also fitted with a high spec Kenwood ICE system consisting head unit, graphic equilizer large amp behind drivers seat uprated speakers in the doors and subs in the storage boxes.
The car is also fitted with a Laserline cat 1 alarm/immobiliser.
Now for the bad bit the bodywork is not so good the passengers side rear quarter has been bumped in the past and filled this has now cracked. So the car could do with having this repaired and a respray. Or you could use it for a rev 3 conversion and have loads of spares. Rev3 rear clips go for about £1500 for a standard one.
The car is MOTed until June taxed until end of September it has done about 70000 miles although the speedo shows less as I changed the 110 one for a 180mph one. the car is also derestricted.
Now for the pics
Please contact me via PM with any questions but please remember I am only home on weekends and have no internet access during the week.
[FINALIZED] 1994 rev 3 T bar GTS turbo
Re: [FINALIZED] 1994 rev 3 T bar GTS turbo
All pm's replyed to.
is this still for sale?
wondering the same thing, but no reply to PM so far
Yes its still for sale sorry I havent been on here for a while been working away from home with no internet access.
is this a cat c or d? or neither
Price drop to £1900 as it is or £1600 with standard seats fitted and apexi removed.
I have never checked to see if it was registered but the plate is visable so you can check it if you want.
Heya,
Is this still available? Also where in South Wales are you?
Marcus
Marcus
The car is not on any accident damage register and is booked in for a new MOT next Saterday.
McDisco wrote:Also where in South Wales are you?
I'm interested but could do with knowing the above?
Andrew
