smokeejoe wrote:
Will definetly avoid cellulose as im sure to swear when it reacts and make it even worse.![]()
smokeejoe wrote:Hello im going for a full respray on my project mk1![]()
attackoftheeddiemunster wrote:
Just paint straight to air with arsehole cans.
Erm..
What?
sketch wrote:Hmm..
.if Smoky wants to do a decent job, rattle cans are not ideal in my experience.
Single panels
? Yeah maybe.
.if a good colour match is found but not the whole car
Besides, the amount of rattle cans he'd have to buy would work out more expensive than a few litres from a paint supplier.Also I find with rattle cans, the spray pressure varies from can to can as does the consistany.
If he's gonna give it a go, he may as well learn to do it right.![]()
Tiamat wrote:
Thats why if you do with aerosol cans, you should remove the car fromt he road, set up, prime etc, tape off EVERYTHING then doa very light dusting using one can over several panels.![]()
Build up the colour really slowy, that way any inconsistencies in the spray is hidden.
However as you say it works out BLOODY expensive and is cheaper to get a few litres of something from a supplier.![]()
However it can be done, I have seen a few like this that have worked out well.
