Anyone using them?
Is this one any good?
http://www.coveryourcar.co.uk/store/pro ... ctid=16362
Car cover
Re: Car cover
HOW MUCH!!!!!
Re: Car cover
I know, not cheap is it! That's why I was wondering if it was any good, or what it did that other covers didn't?
Re: Car cover
i guess fit the car, but i would just get a over sized cheap one. its only a cover
Re: Car cover
Argos sell different ones, i bought one that had a soft inner lining for around £30, was quite a good fit, give me a minute and i will get a pic
Re: Car cover
Martin F wrote:Argos sell different ones, i bought one that had a soft inner lining for around £30, was quite a good fit, give me a minute and i will get a pic
Re: Car cover
Is this an outdoor one Martin?
Good value if it is.
Re: Car cover
what stopping people stealing it, most i seen is a eyelet on the bottom to lock it
Re: Car cover
If it's an outdoor cover you need and you don't want a loose fitting plastic cover wearing away your paint and moisture being retained that leaves water marks over your paint then that's really about the cheapest one you can get. I had one and it was pretty good for protecting the car over a few winters. Only thing is it's tailored for rev1-4 spoilers and didin't fit too well with the rev5 at the back.
I would steer away from cheap, poor fitting covers as you'd be better off without anything at all IMO.
Re: Car cover
It's the whole 'breathable isn't waterproof' and vice versa that I can't get around.
My car is outside, I've just fitted Rogue fans and noticed straight away that the engine is getting wet, and my boot leaks
Want a waterproof cover, but heard that fully waterproof can do more bad than good for the paint?!
