Need Some Advice - Fitting A CT20b To Rev2
matt_mr2t
Post by matt_mr2t »
Ok - I know the stud pattern is different, what needs to be done?
Will I need any gasketts, if so do I buy rev1/2 or rev3 gasketts?
Is it worth me getting an uprated actuator for it?
Should I get my Dastek re-mapped too?
Any one in Essex or may be London wanna take on the job for me?
matt_mr2t
Re: Need Some Advice - Fitting A CT20b To Rev2
Post by matt_mr2t »
And another thing - will the hose from the indcution kit still fit the housing?
EarL
Post by EarL »
Oil feed pipe is different from what I can remember (mayby JJ or Dino can clarify), but gaskets and everything else are the same - apart from the extra stud that needs removing.
HTH.
EarL.
matt_mr2t
Post by matt_mr2t »
Is it much work to mod the oil feed to fit?
