For those that have fitted these mirrors ,could you tell me how the wiring colours match up ,the plug on the mirrors is a different shape and size to the plug on the car
Ive searched through the site, and cant find anything relating to the wiring
also does anyone know how they come apart, so they can be sprayed ?
[Mk2] [Generic] Ganador mirror wiring
Re: [Mk2] [Generic] Ganador mirror wiring
Sorted now ,all fitted and working
Pics??
Dans Modified MR2 Turbo >>> http://www.imoc.co.uk/forums/garage.php ... e&CID=2727
D4N_V_U wrote:Pics??
What do you want a pic of ,the mirrors or how they are wired ?
Just wanted to see how they look fitted mate
D4N_V_U wrote:Just wanted to see how they look fitted mate
Ill stick one up at the weekend mate ,im away at present
BLZ-8027 wrote:Sorted now ,all fitted and working
Hi mate how'd you wire it up then? I need to mate my set to the car wiring soon so any help would be appreciated
Well i finally got chance to finish these mirrors today
i was going to strip out the three wires from the mirror plug, and fit them one by one into the mirror loom ,
however the more i looked at the plug the more i thought it might fit ,so i cut off the two sides to make the plug smaller ,and it fitted straight in and worked ,so no need to mess about trying wires
Heres how the wires match up ,
Ganador mirror plug
cut down plug connected to mirror loom
(it will only go one way to make the connectors match)
so its
Black to Blue
Brown to red/brown
Blue to green
Also depends on your current set up ,if you have the five or seven wired mirrors the ganador are plug and play anyway
Need them painting now
Ganador mirror plug
so its
Black to Blue
Brown to red/brown
Blue to green
Thanks for that. I didn't get the harness/plug with mine but this will help me hardwire them in
I thought your car was black, can I see cosmosblue or shall I book into specsavers?
Yas wrote:Thanks for that. I didn't get the harness/plug with mine but this will help me hardwire them in
No need to go out to the shops
my last car was black ,this one is dark purple
the mirrors are cosmos blue though
Try and get an old plug from some mirrors ,ive got one you can have
I'm gonna chop the plug off my standard mirrors to 'plug-in' to the car harness like they would be normally, then solder the other end directly onto the mirror... from what I remember there are 3 pins on a chip board inside the ganador(i'm missing the plug that would clip onto that board).
The plug in your pic does that plug straight onto the mirror?
The wire from the plug in the first picture goes direct into the mirror
Do you know how they come apart, i need to get mine painted ?
Get hold of the base plate bit, grab the mirror part and push it backwards and away from the base plate.
If they are still fitted to the car place your palm facing flat onto the mirror and push away, probably easier to sus out how they separate whilst still fitted to the car.
You should get them to part enough to get them sprayed, my bodyshop wedged something inbetween to keep them apart, from what I remember they are held together by springs which look like a pita to refit into place once taken out.
They are spring loaded ,and dont look easy to go back together ,im just going to remove the glass to paint them ,and as you say wedge the actual mirror away from the baseplate
thanks
thanks
