Touge_AW11 wrote:Is the aftermarket for these cars that bad? What's wrong with the BC/D2 stuff? They're made in the same factory as the K-sport coilovers used on lots of other cars?
tonigmr2 wrote:Nobody rate Leda anymore?
LeSpank wrote:Not having a go here but a lot of people don't care about spring rates, damper valving etc.
LeSpank wrote:Is anyone going to own up to having the holy grail of Konis with the Ground Control/Rally Design coilover sleeves?![]()
kaiowas wrote:LeSpank wrote:Is anyone going to own up to having the holy grail of Konis with the Ground Control/Rally Design coilover sleeves?![]()
I have a set in the garage, got a couple of things to sort out on them before they go on the car, should hopefully be doing it this winter.
aw11rally wrote:I'm tempted to try some rally design sleeves on my mk1.5.
Has anyone experimented with spring rates? I've read 4kg/mm front and 9kg/mm rear but I've never tested the rates on any of my setups.
Tiamat wrote:Whats wrong with good old fashioned KYBs?
