My car came with crap lexus lights and a rev 1 panel when I bought it, so these were swiftly changed for original Rev 3 lights and panel
It has been fine since fitted, until last weekend I noticed the reverse lights wre not working, but after selecting neutral then reverse again, they do ???
Could someone point out to me where the switch is for the light so I can check it. As I say, it works on and off, more off lately since the weekend tbh..........
Thanks in advance
Tony
[Mk2] [Turbo] Reverse lights intermittently working
Re: [Mk2] [Turbo] Reverse lights intermittently working
Hi Tony
The reverse light switch is on top of the gear box, if you pop the engine lid and look in from the passenger side you can access it from there.
http://www.imoc.co.uk/forums/kb.php?mode=article&k=86
Hope that helps
Adam
Hope that helps
Adam
thanks for the tips !!
I'll tackle that at the weekend if it stays dry
