hiya, my 5th gear on my rev1 n/a has almost gone, so insted of refurbing the box, after talking to some people have decided to change it for a rev3 box as am told is a stroger box.
Has anyone else done this an can offer any advice? and what else i need to change, ie, driveshafts, linkage cables, mounts????
i belive that the box is a rev3 n/a, not a turbo!
cheers dave
[Mk2] [NA] rev 1 gear box to rev 3 what do i need?
Re: [Mk2] [NA] rev 1 gear box to rev 3 what do i need?
you will need to change the gearbox mount, apart from that its a straight swop
The biggest issue is that rev1's are a cable driven speedo and rev2+ are electric so you're going to have to sort that out.
I don't know how though but I suspect others have done it!
I've fitted a rev4 box to my rev1. Both boxes were for tubbies though so I don't know if it's exactly the same for na?
All I really had to change were the driveshafts. The new box had an lsd and needed different shafts but other than that it was pretty straight forward. I think the speedo drive carries across so you just need to fit your existing rev1 part into the rev3 gearbox housing.
Wingers
Wingers
cheers, will see what happens next week when i do it! knowing my luck somthing will go wrong! lol
