Hi Guys,
few years back my HG popped and it was replacecd by the garage i bought it from. They invoiced a whole gasket set, so everything from the HG to the zorst manifold gasket (which appears to be made from metal)
Now i understand the orginal Rev1 HG was pap and made from paper, my question is was this something Toyota later revised? or if i was to purchase a OEM Rev1 Headgasket from Toyota would it still be made from paper?
My headgasket change
Re: My headgasket change
If you are going to change the head gasket again just use a REV3 one, its all metel.
Bob
Bob
Why are you changing the gasket again while its fine?
Anyway, how about going SLIGHTLY higher compression ratio with a TRD or something HG?
Perhaps i was a little unclear.
My headgasket change was refering to the one i had done when i bought the car. Im not planning to change unless it pops.
My question was if the garage who changed it went with an OEM Rev1 HG from MR T is it still made from the same pap it was 20 years ago or is this something Toyota recognised and changed?
it will be the paper one bud.
James
James
ah ok. Acutally whilst im on the subject how much do you guys charge for a HG change? Also cambelts due soon and as im in the south i'll prob bring it to you guys.
You mean the garage fitted you a new head gasket but failed to fit you a new timing belt? What a crappy service they gave you.
While your having the timing belt done, replace the water pump
