![Laughing :lol:](./images/smilies/icon_lol.gif)
Paul White wrote:BUY APEXI
IT IS THE BEST..
good price too.
apexi is great!!!! sounds sweet too..
THE ONE TO BUY.
I can do a recording if you like???
peterguk wrote:Size is irrelevant.![]()
Flow rates and filtering ability is all that matters.
Both Apexi and K&N are top makes, but i go for(and have) the Apexi since it retains the expansion chambers which assist in maximising low end torque.
Take a look here for a back to back test:
http://www.mkiv.com/techarticles/filters_test/2/
What are people's opinions on air temperature and induction kits? I can't help think the standard airbox is taking in cooler air than any induction kit which just sucks in hot air from the engine bay, being quite close to the turbo.![]()
(Also applies to NA cars, just not as high temps).
I've got the means to do some temp testing, so will hopefully have something to report in the near future
(Part of my job is assessing engine installations in prototype vehicles, albeit diesel engines, but the same principles apply).
induction kits can take more air in than stock filters but they too need a supply of cold air otherwise they can be less efficient than stock.
secondly, toyota did spend a lot of money locating the air intake where they did to get the coolest air into the engine
and also tuned the intake lengths and chambers to get maximium power from the engine.the resonator and chambers are not just there to reduce noise, but also because resonance can be used to increase the power of the engine.
KiwiMR2 wrote:.
I read a good article in an Australian fast four mag like 3 years ago where the dyno tested a car with a mixture of different resonators, even used a coke bottle in one test& nothing at all.
All on the same car etc.
the left the OEM setup all bar the resonator and the OEM one came out with the best performance.
IMO an aftermarket panel in the OEM box is better for a MR2 than a pod in the engine bay..
.unless you go to the effore of boxing it off.
KiwiMR2
aandy wrote:guys make my day.i will like to know, advantages and disadvantages of air induction kits.
convince me to buy one or, not to buy.
if BUY wins
what is the best brand
