So, ill try keep this brief if i can
(proof reading this and i may have got carried away!).
Changed my thermostat the other week for a mr-t proper job one
(tested, works fine).
When we changed it, we flushed the coolant out from rad, pipes under car, and the block.
Then we put rad flush in and we got all the crap out the cooling system, its mint.
So anyway, when we replaced the coolant with halfords advanced mixture
(50/50 mix) we used a snap on venturi valve jobi, which creates a vacuum and sucks all the air out the system, then pushes coolant in, so there is no air at all.
Right so my problem is, i didn't do up the bleed valve
(bottom drain tap)at the radiator end properly
(rushed it, like an idiot) so when i was on the motorway, it overheated, finally got home, after i had a strop i realised the next day that it was dripping, so we thought as it hadn't lost alot of coolant, it drew air in causing airlocks, not a lack of coolant.
So i replaced bleed valve just incase on thursday, but once i had i did a manual bleed without the fancy tool, following the oc instructions.
Ever since, the temp gauge rises completely at random
(not overheating as such) for example i drove it hard tonight, almost full boost for a few seconds and when i pulled up.
.fine, not a murmer.
.parked at shops, drove home normal, pulled up, the gauge started rising slightly but when i rev it abit the gauge comes down again?!
I'm guessing airlock right? As in the water pump is spinning faster, dragging the water and air lock with it?
Only bled it thurs/fri, maybe this is normal?
Any idea's guys? Sorry for the essay! Bit of light reading for ya!
Thanks in advance, Dave.
