Hi all,
Im a newby on here.
Just picked up a little project MK1b
(MR2 no.
5! Theyre very addictive!!).
Gfriend knows nothing about it yet so its sitting round a friends while i work out how to explain to her that i let her down last minute on sunday to drive 200miles
(each way) to pick this up
Last taxed in 2004!! Been sat in a garage for a number of years until the last guy bought it as a project but due to moving gave up.
Had a new rad and a couple of other bits but believe it or not, with a set of trade plates on her she drove back fine!!
(after spending an hour on his drive bleeding the air out of the cooling system!).
Amazed everything worked too!
Anyway, going to need a few little bits before shes back on the road permanently
(hopefully!!) but ive got a few questions:
The front suspension seems a little high.
My last MK1 had Koni adj's on it and looked just right so i expected this to be a little higher but it looks like its on transit springs.
Defo just the stock susp.
Any ideas?
Also, i appreciate it will need a good service which it will get next month but the guy mentioned it idled odd.
The car hadnt been run when we got there, started up lovely
(amazing Toyota engineering
- well little help from yamaha!) but after a few minutes of idling the revs started bouncing between 500-1000rpm.
Continued to do this.
could this just be the idle control valve
(if so anyone got a part number/idea of price? gulp!!).
Cheers for any help
