ALL depends on where its mounted.
i run a sidemount, and generally get 10-12 above ambiant roughly on cruise, another 5-10c when on boost.
mat sensor in stock location, powerFC, PP intercooler
so
(this time of year) i see low 30s, then creaps up to high 30s on boost, this however is with a stock sensor, 1.4bar of boost.
im the person your refering to thats fitted a more responsive sensor, believe me it wont feel you with confidence if your seeing high temps with a stock sensor, youll see
'more' on boost with the other sensor as its quicker to respond.
with the new senser i see temps going into the 40s to high 40s on boost now, which is a truer reflection of the temps compared to a slow responding stock sensor.
but cruise it will drop down much quicker than the stock sensor.
for folks placing before the TB, or in the boot near there boot IC, id expect not much above ambiant, and only a small increase on boost.
this position has a constant air supply unlike the stock position.
the sensor wont be picking up the high ambiant temps in the manifold, hense the lesser temps.
whether or not folks should be tuning to temps before the TB, or after
(in the manifold), is up for debate, the orginal sensor after all is called a
MANIFOLD
Air
Temp sensor.
you will likely see different temps from those locations due to heatsoak when the thorttle is closed/barely open, plus on boost its attached to an ever temp increasing manifold.
be interesting to see a before TB and oem sensor reading at the same time.
