Hey i would but ive already done it im afraid, although i will be taking it off as soon as i have a turbo timer so i can fit that too.
So ill check then for you
QUESTION:
The existing hose running to my boost controller.
can i put a
"t section" in it to run some pipe to the turbo timer too? Ie utrbo timer and boost controller both getting their readings from one the same pipe.
Or will this affect the pressure readings etc? Very noobish question i know!
Joe
