i have a power fc for a rev 3 i also have the solenoid for the boost control, in the kit for a revf 2 you get a map sensor so it shows boost onthe controller, mines a rev 3 so already shows this is there any way to just wire up the solenoid ???
so ive had a read around and the pin out of the ecu are signal earth and power, so can i just hook up the solenoid to the earth and power and run a cable to the standard map sensor for the signal although it already reads on the controller
