[Mk2] [Generic] Any shocks apart from yellow bilstiens?
For the Rev2+ cars are the only after market shocks available the yellow bilstiens? Apart from coilovers.
Re: [Mk2] [Generic] Any shocks apart from yellow bilstiens?
To the best of my knowledge, yes. It's either standard shocks from Toyota, Bilstein B6 or rebuilding original shock absorbers with inserts.
theres g max too. i had them on my old astra and rover coupe. the springs were not low enough on either of those cars though.
http://cgi.ebay.co.uk/Toyota-MR2-Mk2-19 ... 5885d3b966
I'v heard Koni are alright. Not sure if anyones tried them? They do a kit: http://www.europerformance.co.uk/pages/ ... t=15346264 Was thinking about getting some new shocks myself so would be interested in others advice.
tried spax and koni inserts and they are ok on the softer settings.
used -40mm springs with the koni and -30 with the spax.
even on the bumpiest b roads i could find they were not too harsh when set to the lower settings.
the koni's lasted 5 years of hard driving, drifting and track days.
only replaced the konis with spax as they were 30quid cheaper and it's only a daily driver.
they did kill a lot of drop links though.
Don't discount a secondhand set of black billies.....
R
PS If you're considering yellows for a daily driver be aware I've just replaced under warranty my second front strut (the first went 9mths or so ago) put on my daily driver less than 2 yrs ago with Teins. The strut is replaced but I'm still left paying for the diagnostic and swap work. May depend on your springs though?
R
