it can varies on temp and oil type, ie.
you'd see lower pressures with say 5w30 than you would with 10w 40.
i use 5w 40 and i get
6.5-7 bar on cold start up
6.5-7 bar warm with high revs
(about 6k+ rpm)
and about 2.2 bar on warm idle.
one bar does seem a little low but iirc, its at about 4 psi pressure which is danger zone.
hth.
