I want to get my wheel centers on my split rims the same colour of the car and to get a decent match. So what is the easiest pannel to take of the car to match it with (+ what needs to be done to remove)?
My first thought is petrol cap?
Easiest painted pannel to take off?
Re: Easiest painted pannel to take off?
Engine inspection panel (the two panels either side of your engine lid)
Edit: you'll need a spanner
or petrol cap a little smaller to carry and can fit in your pocket.
Bonnet
... Joke, as above
... Joke, as above
Engine inspection panel 100%...
2 x 10mm bolts in the engine bay, easy money.
1992 MR2 Turbo GT-S
1/4 Mile Best: 14.30s
cheers guys
ashman wrote:Engine inspection panel (the two panels either side of your engine lid)
and a screwdriver i'm sure mines screwed in
the inspection panel seems flimsy and could get dented easily
if its a rev3 on then the centre panel between the rear lights
Id go for the inspection panels too, if not, a headlight cover can be removed in seconds!
Andy
Andy
- IMOC Committee
jasongtr wrote:if its a rev3 on then the centre panel between the rear lights
+1. 2 screws and 1 electrical clip.
I must admit, I did the petrol cap in the end, 2 x 8mm bolts. Bish bash bosh done.
hate to say it but i told you so easy to take off and fits in your pocket what else can i say.
