I put the replacement on yesterday and it was all working fine off the car, nice and smooth, but when I put the wheel back on and did up the nut
So something isn't right, is there supposed to be a washer under the centre nut, cos the garage binned it?
Here are some pics of my steering.
Here is the steering column, the thread is a bit rough at the end, but the nut still goes on fine.
![Image](http://i806.photobucket.com/albums/yy343/stephennclark/2010-06-06192303.jpg)
Here is the column with the indicator ring pushed right back
![Image](http://i806.photobucket.com/albums/yy343/stephennclark/2010-06-06192317.jpg)
Here is the back of the momo boss, look how far down inside the splines start, so it has to go on quite a way before they even engage.
![Image](http://i806.photobucket.com/albums/yy343/stephennclark/2010-06-06192332.jpg)
This is what the boss looks like, it's got crud round the top edge because it goes inside the cowling if the cowling is fitted, and if I don't file enough off the cowling to open the hole up then the boss files its own hole.
![Image](http://i806.photobucket.com/albums/yy343/stephennclark/2010-06-06192347.jpg)
This picture shows how much gap there is when the splines have only just engaged, the ring has already been pushed in a little way.
![Image](http://i806.photobucket.com/albums/yy343/stephennclark/2010-06-06192443.jpg)
And this is how much gap there is when the nut is done up tight enough to stop it coming loose when driving, it has already crushed the black inner sleeve as the ring has gone back as far as it can and exposed the black guides, then the boss just crushes them.
![Image](http://i806.photobucket.com/albums/yy343/stephennclark/2010-06-06192638.jpg)
So what is wrong with my car?
It annoyingly squeaks and creeks too, it did that before I tightened it down and broke the bush/guide.
