Would anyone be kind enough to supply the part numbers for the gaskets on the Dizzy, the outer ones onto the engine. Inner ones appear OK.
Thanks in advance.
Stuart
Part number request
Part number request
I asked God for a bike, but I know God doesn't work that way. So I stole a bike and asked for forgiveness.
Re: Part number request
That's for the Mk2 turbo though, don't think it's the same?... awaits to be proven wrong
Sorry sheriff
Edit....it has 3S-GE part numbers as well (don't know if thats helps tho)
which gaskets ? as far as I know there's only a 'O' ring and a dust seal on the distributor
If it's the 'O' ring you want then the part number is
96711-35030- :RING, DISTRIBUTOR HOUSING O
It'll be the o-ring round the dizzy shaft that Stu's after. From the piccy it looks like they're only available as part of a kit or whole unit?
If it's 19107A on the diagram then that's the part number I posted
jimi wrote:If it's 19107A on the diagram then that's the part number I posted
Yeah that'll be the one. I should learn to read.
Excellent. Thanks chaps
Stuart
Stuart
