Hi guys, im a newbie on MR2's (used to own a celica).
Im thinking of taking a punt on buying a cheap MR2 (as a second car), just wondered what you guys thought, should I stick with N/A or go for a turbo (which i would REALLY like) but as I understand it - more to go wrong?
Is there anything to look for particularly on a turbo, the one im thinking of looking at has a lot of service history but 100k on the clock (1991)? And from what ive been reading, a lot of these engines have been rebuilt!?
any advice would be much appreciated!
thanks!
Dave
Buying a cheap MR2 mk2 (turbo?)
Re: Buying a cheap MR2 mk2 (turbo?)
Rebuilt? I wouldn't say that many have been rebuilt, not in the grand scheme of things.
I did exactly what you are thinking about. Sold my Rev 2 Turbo and bought a cheap Rev 3. I am now putting right the issues it has. The worst part though, is finding issues you didn't anticipate.
For me it's finding out my rear brakes are cream crackered and having to now replace them and deciding to upgrade the brake hoses and refurb the fronts while I am at it!
Just buy with your head, not your heart, and understand that if it's cheap, there WILL be issues, unless you are extremely lucky!
ah ok, so rather its just the things that could go wrong with it being a cheap car, not just because its a turbo?!
the one im looking at its a rev 2 and cover 100,000 miles, should I generally expect a fair few problems?
Well just remember that if it's 100k on the clock, at least part of that will be in KM's, so not quite as high in reality. But at that mileage it will most likely be looking for at least a suspension refresh if it hasn't previously had any replacement parts.
Check the history and see when it last had a cambelt done. I'm sure it's every 60k on these, but no doubt someone will correct me if I am wrong.
Does it have a stereo all wired up? Both my Turbos had their wiring butchered and I had to put this right, although it's actually not that hard to wire up an ISO plug, providing the wiring to the speakers/amps(if it has the active system with one or two subs behind the seats) is still intact.
See what the gearbox is like. It might benefit from new selector cable bushes and an oil change if it feels ropey or stiff, but this is something you may be able to live with (I have thus far). It might also have a noisy clutch release bearing, where the noise goes away when you depress the clutch pedal. This is fairly common and a feature of both my Tubbies. It's more annoying than serious, so again this a job that's up to you whether you want to change that or whether you can live with it.
And check the bottom of the doors for rust, as well as the arches and sills.
Plus find out when it was last serviced, and if it's been a while change the plugs, oil, filters, dizzy cap and rotor arm. Some say do the HT leads but I find these tend to last pretty well. This boosted MPG and responsiveness in both my Tubbies.
Cheap cars are definitely out there, and some will be better than others. You CAN get a bargain, but as I say just be very very careful about what you're buying, but don't expect too much for your money.
HTH
HTH
What he said !! ^^^^
You should take a read through this guide first then ask questions later:
http://www.imoc.co.uk/forums/kb.php?mode=article&k=49
Have you got a link to your one your buying or any known faults?
We ALL make mistakes !!!
bluesmoke wrote:Well just remember that if it's 100k on the clock, at least part of that will be in KM's,
Or if it's still in KMs then it's due a cambelt.
Stuart
I asked God for a bike, but I know God doesn't work that way. So I stole a bike and asked for forgiveness.
Jaspa wrote:bluesmoke wrote:Well just remember that if it's 100k on the clock, at least part of that will be in KM's,
Stuart
i would never say 100k mean part miles, parts KMs.
whoever is converting the car to mph, SHOULD convert the mileage to read the CORRECT real mileage....
i would be peed off if a car read 100k miles, and the owner said, oh but some of that is kms! who/what/when are you ment to believe that.
if the car says 100k miles, then i would value it at that. 100k miles.
That's fair comment Jim but unfortunately lots of them are done that way. You can verify it easily enough if the owner has an original receipt from import and subsequent mots, but it's certainly something to think about if paperwork is sparse.
A turbo should be pretty much as reliable as an N/A if looked after. I had a rev 3 which was still running very well after 95k miles, engine sounded spot on. I'm quite sure it was the original engine and turbo. You can often tell a lot from the history and previous owner's treatment of the car.
jimGTS wrote:...stuff...
indeed, but the OP wrote
Which doesn't say if the clocks have been converted to Miles or are still reading in KM.
and therefore
Jaspa wrote:Or if it's still in KMs then it's due a cambelt.
So ner nerdy ner ner
many thanks for all the replies guys!
the car that I was looking at was this one...
http://tinyurl.com/23cxzfe
he hasnt sold it, but maybe its too tuned and might be risky?
i have about 1000-1500 to spend, originally i had up to 1k, but i figured if i wanted a turbo i would have to up the budget a bit!
thanks,
Dave
thanks,
Dave
dave1814 wrote:many thanks for all the replies guys!
thanks,
Dave
£1k Tubby = Trouble
- IMOC Moderator
i bought mine for 1400, 93 plate rev2, 60k on the clock, every mot since imported, loaaaads of history with it, totally standard, very well looked after, it had reaaaally bad faided paint though, this is the type of car you should keep your eye out for, mine was essentially a 2-3k motor had it not been for the paint, i painted it myself :):) faided paint knocks off sooo much value on an otherwise mint car
- IMOC Committee
thanks,
Dave
I hope you didn't end up buying that one. My money would be on it having had a front end impact at some point in its life, the bumper and headlights don't sit right and one of the trim strips is wrong. It has no side repeaters?! The specs the seller is posting don't really tie up with the engine bay shot, and it's got 2 dump valves which says to me that it's been modified by someone who didn't know what the hell they were doing! Especially considering one of them is VTA on an AFM engine.
For what it's worth I don't think you'll get a sorted turbo that will give you hassle-free motoring for £1500.
nope, ive upped my budget to 2k and might be going to look at this...
http://tinyurl.com/2epavug
least they will provide a 3 month warranty!
- IMOC Moderator
you'll get a better one than that for 2k mate seriously, 100k miles??? i wouldn't pay 2k for that
best bet is one off of here tatha has been looked after, there's been looaaaads of good ones sold over the winter on here
sheppy wrote:you'll get a better one than that for 2k mate seriously, 100k miles??? i wouldn't pay 2k for that
really? OK OK ill wait!
i hate waiting tho! lol
someone sell me theirs for under 2k please? :p
update: i have just found a cheaper one...
http://www.pistonheads.com/sales/1654938.htm
any advice?
might be able to get 6 months tax for the asking price as well? i know its a 1990, but less miles.
any advice?
Looks OK.
I sold my Rev 2 Tubby 6-8 weeks ago for £1600 with Tein Super Streets, TRD rear wing, manual boost controller, aftermarket intercooler, Blueflame exhaust, and about 6 months' MOT though.
Issues were:
Needed new rear tyres
Needed arches rolling
Needed front wings either replacing with properly painted yellow ones or respraying
That was about it.
Decent stuff is out there!
Issues were:
That was about it.
- IMOC Moderator
dave1814 wrote:update: i have just found a cheaper one...
any advice?
that one does look good, plus it's got mot's, i'd buy that for that price, you might even be able to knock a couple of hundred off, tell him you got the cash and you wanna buy, tell him you've got 1500 waiting for him :):)
