hi anybody just give me some quick advice, i ve rubbed my alloys down primed and sprayed in a dark grey and have laquered them they look fine ,but ive read some places that i need to rub the laquer down and then polish them?should i do this?i just dont want to ruin them now when they look finished.some write ups say laquer and thats it,some say t-cut them and some say rub down with sand paper and buff polish them up. which should i do?
steve
[All] [NA] alloy wheels refurb nearly done
alloys
nobody know anything about this?
Re: [All] [NA] alloy wheels refurb nearly done
if they look fine then leave them You only need to flat them down if you have a crap finish but flat too much and you will break through and have to paint / laquer again
alloys
ok thanks looked at them today after lacquer dried look ok could just do with being a bit more shiny, think i might dry the t-cut and polish them
personally i would laquer them then put them in a warm room to dry if you can as the heat will bake the paint and leave a shiny finish if they have been left in the cold to dry they will appear dull and flat
use g3 rubbing compound and a fair bit of water and a micro fibre cloth to polishe them up then some auto glym super resin polish after you have gently rubbed over them and washed the excess g3 off
thats what i do normally
