Be prepared to saw the old droplinks off.
I found the best way to do it
(and I know this might sound a bit extreme) was to saw diagonally through the nuts.
Half the nut will fall away and the remaining part will almost certainly be loose enough to undo with a ring spanner.
Other thing to consider is that you can't fit the drop-links without loosening the bolts securing the hubs to the struts.
I found the best way to do it, with least hassle, was to remove one blot from the strut, loosen the other one.
That'll allow you to hinge the hub and strut outward far enough to get the drop-link in behind the strut.
