I dunno,
I'm always wary of writing things off to coincidence.
9 times out of ten you'll find another cause if you look hard enough.
I can't really see how a hose would cause this.
I've seen something vaguely similar where a 2" hydraulic hose has delaminated internally and allowed oil to flow one way but then stopped it flowing the opposite way but I don't think that'd happen in a brake hose cos the internal diameter is so small.
Perhaps there's something else going on here?
Maybe the caliper mount is bent so the caliper isn't properly aligned or a wheel bearing is damaged so the disk is wonky in the calipers?
If something like that was happening it'd cause the caliper to heat up enough to cause damage to the o-rings.
What about the master cylinder and ABS unit?
I haven't looked at how the brake circuits in the MR2 are built but, particularly if your car has ABS, I assume
(yes, I really
should![](./images/smilies/spacer.gif)
check this stuff out before guessing) it'll have seperate lines to each wheel.
In that case a dodgy seal, or something else, in the master cylinder
(or ABS) could be causing the brakes to be applied unevenly.
Gotta say, from experience, mucking about with master cylinders can be a nightmare.
There's dozens of tiny o-rings which're easy to damage and you've got to do the work in a clean environment or and tiny lump of crud could cause a problem in the future.
Might be better to buy a master cylinder
(or ABS unit) from a scrap car and swap it out.
FWIW, if the car doesn't have ABS this should be much simpler as, from looking at mine, it seems like it's a dual-circuit master cylinder that feeds into the ABS unit which then has 4 lines coming out of it.
If your car doesn't have ABS it's unlikely to be the master cylinder cos the same line should feed both front wheels.
.unless non-ABS cars use a different master cylinder with more than 2 output lines.
![Think :-k](./images/smilies/eusa_think.gif)
