Does any one know if I can fit a rev. 1 distributor cap (non clip fitting for the HT leads) to my rev. 2 distributor body?
I have a set of non clip magnecor leads (presume off a rev.1 turbo) and am wondering if I change to the earlier dist. cap then I can use them instead of swapping for the correct clip type leads.
Cheers,
JB
[Mk2] [Turbo] Rev.1 / Rev.2 Distributor caps interchangable??
Re: [Mk2] [Turbo] Rev.1 / Rev.2 Distributor caps interchangable??
yep...I made the mistake of buying a non clip dizzy cap from Camskill and it fit the dizzy but not my clip on leads
