The rev 1/2 which is larger than.
The rev 3 slightly smaller version.
I have sard 800cc injectors in my bored out rev 1/2 rail.
or niether?
Fit a malpassi 1.7 rising rate type.
Mike
And a Walbro.bobhatton wrote:You have got a programable ECU I hope too.
Jim Galbally wrote:bob, rising rate is what 1:1 means, it rises/falls with manifold pressure to ensure the presure at the injector tip is kept the same.
you're probably talking about the"FSE power boost valve" type regulators which are fit for fitting to your dustbin only
Mike N wrote:Link ecu
Walbro 255(just fitted today)
I bored out the fuel rail myself then welded up the end.800cc sard injectors.
I was going to fit a Cossie FPR as they are adjustable, but could'nt find one in my old pile of garage junk.
What do SBits/ Sard do to modify a std FPR? The Rev3 rail is about 8 or 9mm bore yet the FPR is smaller than the Rev1 which is fitted to a 3 or 4mm Rail.
bobhatton wrote:You need to tell FSE they have their information all wrong then.
"Designed for use on
Electric Fuel Injection Engines with a special fuel enrichment facility for acceleration, commonly
known as aRising Fuel Rate.The enrichment rate is 1.7
: 1.
