[Mk2] [Turbo] Japspeed exhaust plus bung fitting and DB readings
Phill P
Post by Phill P »
Hi peeps
Thought I'd just put a post up about fitting some ebay bungs to my 4.5 inch Japspeed tailspipes.Image
Once fitted will also get DB readings for a normal car (wifes Rover 600 2.0 petrol) and a friends mucho modded Skyline GTS,with and without bungs
At the mo the mr2 at tickover 800 or so revs the DB reading is 80.5 from 1 metre and 45 degrees (taken between the pipes) with no bungs fitted.
Will update as and when.
Paul :thumleft:
Rota torque drifts Japseed exhaust Apexi air filter Gizzmo ibc Apex springs Hks turbo timer 242bhp at .8 bar
loudandproud205
IMOC Organiser
Re: [Mk2] [Turbo] Japspeed exhaust plus bung fitting and DB readings
Post by loudandproud205 »
what db meter will you be conducting research with?
Phill P
Post by Phill P »
Don't know make as its a friends,but it was used at a company that did pa's systems and rental of large screens to conferences so it should be accurate and will give a reference point to what can be done with a simple bung.
paul :thumleft:
Phill P
Post by Phill P »
loudandproud205
IMOC Organiser
thats pretty much what they use at track days but with extended mic so should be intresting to read results.
i tried to do mine with a friends RTA that we used to use for db drag but so far are mics havnt proved to be sucessfull, since phase out of old mics its now bloody hard to anything with them other than stick them in the window and use them for spl tests :(
Steve-O 2007
Post by Steve-O 2007 »
are these the £25 each ones?
Phill P
Post by Phill P »
Yes they are,turned in a couple of days and will try to fir tommorrow depending on weather.
http://cgi.ebay.co.uk/TUNABLE-EXHAUST-B ... 5d280ec916
Paul :thumleft:
lockys96
Post by lockys96 »
track days will do 0.5m at 3/4 revs
make sure your rev limit is 7,ooorpm lol
its a shame there is more mechanical noise from the mr2
Phill P
Post by Phill P »
Ok bungs fitted,didn't get to position them further in the exhaust due to Japspeed fibs,when they say 4.5 inch tailpipess they mean external. Also chopped around and 1.5 inches off the end as its running flush with the slash cut which was badly off centre the 3 inch curve of the exhaust.
Anyways,performance wise it boosts a little slower and up tp .85,whereas before it was around .91.
Noise wise,its like a standard exhaust,all the noise now is the Apexi doing its thing
Will do DB tests at weekend.
Paul :thumleft:Image
loudandproud205
IMOC Organiser
looks positive then may have to get myself one pending noise on the 5zeigen exhaust am getting as it dont look like its silenced very well :p
Phill P
Post by Phill P »
Oky dokey
Slight booboo in that I got me maths wrong and couldn't remember if it was 3/4 or not of max revs so did it to 4500,if I can will re do at 3/4 revs.
MR2 with bungs in
Tickover 76.8 db
At 4500 92.5 db
With bungs out (although cat still fitted)
Tickover 81.1
At 4500 98.6
At 7000 108.8
Did the Skyline gts with no cat and bung in...... build thread here http://www.skyline-owners-club.com/foru ... e-mk2.html
Tickover 78.2
4500 94.5
6000 106.5
Bung out
Tickover 86.6
4500 102.1
6000 107.1
And up the side of the car the screamer pipe was starting to come in to the party at 109.8.
Although boost was low at this point as not loading the engine.
Hope this helps.
Also got to hear mine for the first time from behind :D :D
loudandproud205
IMOC Organiser
interesting read, yours didnt seem as loud as i expected tbh
Phill P
Post by Phill P »
I was surprised myself after hearing all about the legendary Japspeed exhaust and how your hearing will fail in 2 minutes.
Didn't get to test the wifes normal rover 600 for db reading but I suspect that with the bungs fitted plod would pay you no attention at all over your exhaust.
Infact most of the noise at least from in the cabin is mechanical.
However the downside is that although I got to follow my car and hear the exhaust for the first time from behind,and it did sound nice,.......it will never sound as nice as 6 cylinders :(
Paul :thumleft:
lockys96
Post by lockys96 »
well if you can get a fujitsubo legalis r you can get 96db at 5,000rpm on a stroked engine and with wild cams and have 480hp no bungs
Rob
Post by Rob »
Interesting thread - I have these waiting to go in, although I believe mine are a different make.
With the restriction to the exhaust flow, is this likely to cause more back pressure and damage the Turbo?
Phill P
Post by Phill P »
BiGWiLlYsTyLe
Post by BiGWiLlYsTyLe »
I need some bungs for my Japspeed too.
Why wont the fit right into the pipe? Would you need smaller ones bud?
Phill P
Post by Phill P »
Diameter of the bung is 4.5 inches,however Japspeed exhaust internal diameter is less :? by a few mm.
Rob
Post by Rob »
Thanks mate, although i am not sure on just 1 persons opinion. With the stock exhaust the gasses go straight out of the pipe and not bounce back off the solid wall of the inner faces of the bungs which could cause a pressure trap.....
Phill P
Post by Phill P »
Unfortunatly no one else commented :(
Paul
