next to it is what i would believe to be the hose but its been blocked by a bolt in the end and a t off for my boost gauge.
is this right what was it meant to do??
the boost on mine is runnin at 14.5 psi
cheers
Steve-O 2007 wrote:with it disconnected you wont hit fuel cut either![]()
mr2turbo99 wrote:i spliced into the hose that comes from underneath this black box with a T-piece for my EBC pressure.Will this be ok?
zombie_dave wrote:in which case why are they on the na's aswell?![]()
