Will try to get the videos onto youtube at some point today
Didn't have to touch the suspension turret, just mounted the engine on nylon mounts cancel out any movement.
So to expand on the issues.
Firstly, I didn't really feel that the beams engine was as pokey as it should have been, but I'm thinking it could partly be down to the gearing.
I'm currently using the box out of the st202 celica superstrut with 4.2/4.3 FD, which will be changing to 4.7/4.9
(forgot exact figures!) Furthermore I m looking at installing ITB's to help the situation and get it re-mapped at a more reliable source.
Gear changes are far from crisp due to the long throw and very sloppy selection.
Plans are to flip the selector shaft round and have the original gear cables again.
I'm also wondering how effective these aftermarket quick shift levers are, any feedback?
Last but not least is the grip level.
That hill climb was notorious for being slippery, but when looking at spectator footage I can't help think that the mr2 lacked a fair bit! Here's some footage.
I'm thinking this is partly due to the fact that I'm running 185 width tyres all round.
Looking around the
'paddock', most of the other competitors
(escorts and exiges) are running very wide rear tyres, which might be a clue! Now my dilemma is whether to increase just to rear, to say 225, or increase the rear, and increase the front also
(keeping the same ratio of rear being larger ofcourse).
Ideas?
Not to make it look like it was just the car, I think my driving still had a lot to be desired.
Due to the oversteer
( alot more evident in previous runs which i ll get uploaded) confidence was lacking and I didn't barrel enough speed into the corners or use the brakes hard enough as I felt that it would just swap ends on me.
Also my throttle pick up may have been alittle aggressive hehe!
Let the work begin!!
![Dancing \:D/](./images/smilies/eusa_dance.gif)
