Having used the search function and read various extended wheel stud posts I haven't quite been able to find the answer I'm looking for so was wondering if someone can help me?
I've just bought a set of SSR Integral A2 wheels, front 16x7 et 32, rears 16x8 et 38.
Does anyone know if I will need extended wheel studs to fit these wheels?
From what I've read, some people have said that it depends on the number of turns the nuts need before they are torqued but there's some disagreement on how many turns are needed for the wheels to be safely secure.
Also, I'm not quite sure what consitutes a turn
- is it simply the nut rotating 360 degrees or is it measured in another way?
