what is the best way to do the above? Some people are saying
I think i want to go down the route of unplugging the connector as chopping the pipes looks a little tricky as its quite tight.
mr2turbo99 wrote:Hi Guys,
what is the best way to do the above? Some people are saying"chop and plug the pipes off the actuator" and others are saying
"unplug the connector below the inlet manifold".
I think i want to go down the route of unplugging the connector as chopping the pipes looks a little tricky as its quite tight.are the any differences between the two options? Thanks
