Hi all
In the process of removing the ct26 rev2 on ramps outside in the cold.
i am struggling in removing the hard metal oil pipes.
just looking at removing the pipe from turbo but cant seem to get on one nut.
then tryed looking at removing the big bolt from the block.
i can get it loose but
cant get it off,
Also will i have to swap over the oil pipe that goes to to the sump
.will i have to use the ct26 pipe as it looks like different connection going back to the sump.
On the existing ct26 pipe its just a push on connection to the sump and on the ct20b is screwed connection.
p.s
Its bloody cold and wet outside lol:(
cheers
dave
