are they worth getting or is it purely cosmetic????
i know ebay do dodgy ones, so wont be getting any from there, where else can i get them???
jimGTS wrote:do these items actually improve anything above standard on the car??????
cantfindausername wrote:The TRD Rad cap is rated to 1.2 bar I do beleive where as the OE one is 0.9 i think.
The rad cap combined with the oil cap give aprx 5whp afaik![]()
Pretty pricey for the parts, but worth it if you're going for a dressy engine bay.
Pretty cheap if you happen to be in Japan.
I may get a few later in the year to flog when I get back.
aaronjb wrote:jimGTS wrote:do these items actually improve anything above standard on the car??????
In the case of the rad cap:
Unless you're running a hotter thermostat, or having overheating problems, or needing to run the engine at a higher temp than normal..
no.
Running a higher pressure rad cap will let you run the water hotter before it expands so much that it barfs coolant into the overflow, basically.Which should help stop you getting air sucked back in if you're running hot, plus it'll stop the water boiling
(and hence expanding) for longer.
Assuming nothing else blows up first
CosmosblueMR2 wrote:cantfindausername wrote:The TRD Rad cap is rated to 1.2 bar I do beleive where as the OE one is 0.9 i think.
TRD rad caps are rated 1.3 and 1.5bar![]()
maybe you can gat get a 1.2 one too dunno about that.
higher the rating on the pressure cap the higher the boiling point on the coolant= better cooling.
- so no not just cosmetic Jim
jimGTS wrote:CosmosblueMR2 wrote:cantfindausername wrote:The TRD Rad cap is rated to 1.2 bar I do beleive where as the OE one is 0.9 i think.
where can i get one then sonny!?
CosmosblueMR2 wrote:but make sure your coolant system is upto taking the extra pressure..
0.9bar
upto 1.5bar
- otherwise it will get messy
jimGTS wrote:sounds like the rad cap may be worth it, what about the plugs and leads they sell??? are these any good???(may as well buy in bulk, you no what there delivery prices are like).
but is the trd oil filter werth it?? as its changed every 3-4k miles???
Lauren wrote:jimGTS wrote:sounds like the rad cap may be worth it, what about the plugs and leads they sell??? are these any good???(may as well buy in bulk, you no what there delivery prices are like).
I would say the TRD filter is a waste of time.Likewise for the leads and plus, you are just paying for Blong tbh.
OEM leads are more than sufficient.I guess teh TRD ones won't be any worse, but they may be more expensive.
Remember OEM leads are close on
£100 so i'd weigh up the costs as you may find TRD ones are in fact cheaper! Order from the states its always way cheaper that way.
Anything we need that is over say£50 gets ordered from teh US.
jimGTS wrote:CosmosblueMR2 wrote:but make sure your coolant system is upto taking the extra pressure..
0.9bar
upto 1.5bar
eh??
how would i know that???
(have got a coolent change coming up soon).
CosmosblueMR2 wrote:jimGTS wrote:CosmosblueMR2 wrote:but make sure your coolant system is upto taking the extra pressure..
0.9bar
upto 1.5bar
eh??
just make sure all your pipes are in good nick..
and all clips are woking properly etc etc
just the general condition
- so you don't spring a leak what with upping the pressure in the coolant system.
.the only thing I can promise for sure is slow progress.
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.![]()
Shmed wrote:1.Is the higher pressure actually beneficial in a highly tuned motor?
Shmed wrote:2.Does the pressure
'surge' when you turn the car off? I think I read somewhere that once the system is no longer under pressure, the water boils up
Shmed wrote:3.Will it happen again if I make sure the jubilees etc are tighter?
Shmed wrote:Wow, the search function! Awesome! Yesterday, I decided to take the 2 to work to enjoy the last swansong of the summer.I got close to the motorway and then noticed the engine temp was high.
Glanced in the rear view mirror and saw steam whipping out the engine bay so quickly pulled over and killed the engine.
I have a few pieces of bespoke heater pipe, and also a Blitz 1.3 bar water cap, and TRD low temp thermostat, and I have also raised the rev limit to about 7500k redline(so water pump will spin faster, which I guess would create more pressure, if it weren't regulated by the filler cap?!).
Turns out that one of my bepsoke pieces of pipe hasn't got welding'bead' to stop pipe slipping off, and now my coolant is gone.
When I got home, I noticed a pool of coolant on the drive where the car was parked overnight, and a trail of coolant going up the road, so I think the pipe had popped off overnight
(after I gave it a spirited drive to footy on wed night).
So anyway, to cut to the chase:
2.Does the pressure
