Set off to work this morning and it was abit hesitant, thought it could be the wet weather and the dizzy cap not mixing well!
Tried giving it abit of a run on way home, so im on the motorway of all places and still accelerating, and there was a big flat spot and the ECU light came on.
Gets home, i did the paper clip trick on the ECU and it came up with 25 AND 34!! Googled it, and apparently the codes mean;
25: Air-fuel Ratio Lean Malfunction; Oxygen sensor outputs a lean signal continuously for several seconds during air-fuel ratio correction.
34: Turbocharging Pressure Signal; Fuel cut-off due to high turbocharging pressure.
I haven't got a clue what this means, and abit concerned especially about the turbo bit.
also to bear in mind, its been smelling really rich recently and it bloody rinsing the juice!!
Thanks for looking and help in advance.
