Yeah it is pretty obvious
Black cover is held on with 2 screws either side, then kinda comes out forwards with a bit of persuasion.
Headlight cover is held on with 2 bolts either side then just lifts off.
Take your time to get the panel alignment right when you put it back on, tighten them up and then take the headlights up and down a few times to make sure the panel gaps are rightish. Don't overtighten the screws for the black cover because they're self tappers and will shred the yellow plastic inserts that they screw into.
