jimGTS wrote:just wona bump on this.
my droplinks seem a little loose, rotate quite a bit.
there due a replacement, however when looking at them, i didnt see any sort of allen key hole.
just a bolt/nut one end and that was it??
this normal, oem?? or is it likely i have some generic one on there? doesnt look fancy, looks pretty oem.
i also noticed my arb bushs seemed pretty split and cracked.
ARB upgrade time is it?
Jim, i had to replace a strut recently and found the same
- no allen key hole, just the stud and nut
(the rears however, do have them).
On mine, at the base of the stud, there is an oblong piece of metal, the flats of which you can grip with an open ended spanner
- in my case i think it was 13mm with the nut being 14 mm.
Dont know if this will help, but thought i'd mention it in case you have the same problem.
Im assuming that the droplinks i have on the front are aftermarket ones, or from the days were droplinks seemed to be only avaliable from Mr T and there from another car.
