Earlier in the year I took my car to Luke at Pacific Works to have some stuff looked at. It was the first time I'd met Luke and I spent the day at his place while he was working on my car. At some point while we were chatting Luke mentioned that my Veilside rear bumper was a great shape for having a diffuser fitted and it was something he'd always fancied having a go at. It got me thinking and we talked about it again on a subsequent visit. Another thing that came up was fitting some ducting to get cool air to the front brakes and dressing up the engine bay. The more I thought about it the better it sounded so I decided to go for it.
My car has been at Lukes for the last few weeks having these mods done as well as a ton of other work I threw at him. I wasn't sure how I wanted my engine bay dressed or what design the diffuser should be so basically let Luke get creative and come up with something that looked good.
I picked up my car this afternoon and to say I wasn't disappointed with the end result would be a major understatement!
Engine bay and back end before :
The finished article
The transformation in the engine bay is amazing, I was blown away when Luke lifted the engine lid
Aside from painting the core, the chargecooler system had a complete makeover. The cinq rad was replaced for a GT4 rad that was fitted without having to remove the air con rad. Result!
The chargecooler core had to be replaced as when the lagging was removed for painting we found a nasty surprise Somebody had previously hacked it up and done a really bad welding job as there was a 3" crack along the weld which was leaking boost straight out the bottom
All the CC pipework was replaced with high quality reinforced pipe and the gutless pump that was on there was swapped for a high flow rate marine pump. The pump is located near the filler neck, you can see it in the last engine bay shot. The charcoal canister was relocated to make room for the pump and is now behind the Arc box. The CC overflow is situated right in the corner of the engine bay.
I'm really impressed by the quality of work and attention to detail, from things like the core being raised slightly so it doesn't heatsoak so quickly right down to the use of numerous clips to keep the pipework tidy
This was practically a new chargecooler installation and I'm happy to say that I got the Kingsmill installation this time without even having to ask for it
For the brake ducting Luke used existing holes in the sides of the Veilside front bumper. The holes are behind the flared bits so you can't see them but in a perfect place where the air is channelled through the bumper. The ducting is fibre glassed to the inside of the bumper and shaped to fit into 3" fittings in the wheel archliners. It worked out really well and should be pretty effective at keeping the front brakes cool as they're getting loads of air now
You can see the ducting through the bumper below the sidelights
The diffuser is probably the best bit for me. Luke and his fabricator mate have done a great job with the designing and fitment and I think it looks wicked
All in all I'm really happy with how it's gone and can't sing Luke's praises highly enough
He's a top guy with great creative vision and an eye for detail. If you want a proper job done to the highest standards with no corner cutting yet still at a competative price then he's your man every time. A proper MR2 specialist
Cheers Luke, great job
Pacific Works Makeover
Re: Pacific Works Makeover
Looks awesome mate... especially the defuser
Wow! Very impressive
I like it a lot, nice to see a green instead of the usual blues and reds
Nice!
how do i get a diffuser too then Luke?
Hi Moo,
Saw your car at Luke's when I dropped in last weekend.
The charge cooler finish is great and really suits the engine bay.
Another top Pacific Works - Luke & Harry special.
love it
diffuser looks awesome!!!!!!!
I've seen better
The rear diffuser is A1, shudnt have said Luke did it, now everyone will want one ( of course i knew u were having that done, turned out well)
Top work Luke - loving the engine bay colours and that rear diffuser is aswesome!
My MR2 for sale! Check out the for sale section
very impressive mate
Luke = Genius
Why dont the veilside bumper come with a difuser as it looks awesome really brings it up to date imo
I Remember when i first saw my chargecooler luke done and couldnt believe the finish on it and the sheer attention to detail
Just wish i would of got the engine fans like yours though as it really sets it all off but unfortuately i ended up selling the car another big mistake
Had no problems with Pacific when i had my clutch done there.
Top job!!!
If i was keeping mine id go back and get mine done!
Top job!!!
I can't say I'm surprised at the Results, Luke has always been meticulous about his work and a true MR2 fan and that shows in the quality of the work he turns out. Excellent job Luke
Watch out OZ here I come !!
Looks awesome!
How much does the engine bay dress up cost, and what's included in it?
Excellent results Moo I can see why you're pleased. Luke always does a top job and is prepared to go that little bit further to get things just right.... looks like he and his fabricator have done it again.
R.
R.
Thanks for the positive comments all
I'm dead chuffed with how it turned out, way better than I'd imagined
I've noticed the charge cooler upgrades have helped massively, even taking into account the colder weather. The car feels much more responsive with a core that doesn't leak boost right out the bottom and I haven't seen manifold inlet temps above 30 C yet, even after a run. These are much lower than when it went off the road 2 months ago so it appears the new core, GT4 rad and marine pump have done the job, even accounting for the lower ambient temps now.
I love the diffuser. It looks fantastic and every one seems to agree on that. I've seem some really crappy looking custom diffusers on the back of different cars and wasn't sure how Luke was going to pull this off but he's got it absolutely spot on. The diffuser body is curved to match the lines of the bumper and the fins are at the same angle as the bumper. It's hard to get from the pictures but when you see it in the flesh you can see what a brilliant job it is and how much effort went it to it.
Looks great!
When you next see luke can you tell him to send me an invoice for the work he did for me. Still waiting for it from ages ago!
Truly amazing work.
The diffuser looks awesome
I was feeling bit bored, what do you think of the below
Might stop pigeons nesting in there!!
Some fantastic looking work there!
