Following on from my leaking window thread, I was putting all the trim back in today after the garage resealed the quarter window, and I thought I'd pull out the storage box to see if any water had collected under there.
I found a little, but when I pulled the carpet back I found the foam had soaked up loads.
Can anyone tell me, is the carpet in two pieces, drivers and passenger side, or is it one piece? Would like to take it out ideally and dry it out properly.
Carpet - One or two sections?
Re: Carpet - One or two sections?
If it's the firewall your meaning then it's one piece, it's all relatively easy to remove/replace either way
Nah the actual floor carpet, the water is all soaked into the foam on the underside of that
thats 2 parts
Excellent, will just whip it out and get it dried out properly then
